![]() | Home > Technical (L322) > Fan noises |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
I have tonight been out trying to solve my FBH touchscreen problem with no avail. When sitting in the car and turning the key to position 1 i noticed a fan type noise that seems to be coming from the left passenger side in behind the CD Changer area, no fans any where else in position 1.
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
Hi
Yep pulled fuse 59 which is for the FHB but did not make any difference. It is definatly in by the glovebox but i can not quite pin point it. I opened the bonnet and could not hear anything in there. |
Are you sure it's not coming from your temperature control
Dogman Member Since: 10 Dec 2010 Location: UK Posts: 174 ![]() ![]() ![]() |
As earlier, I don't know if it's the same but it does happen when the FBH is on and also can happen when the car is unlocked.
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 742 ![]() ![]() |
I'm sure I read on here a while back about a fan in the glove box area, that circulated the air when the car was first unlocked. I think it was something to do with interior temp sensors ( Although I can't find it any more in 'search') |
