Home > In Car Electronics (L322) > [Closed - Not Solved] Radio Interference from Laptop Charger |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6412 |
If I plug my netbook charger into the car, it disrupts the radio signal like the radio is struggling to find or stay tuned to a station, like the diversity function has stopped working. Not related to engine speed so don't think it is a ground loop problem. When unplugged the radio is clear as a bell and diversity works well. Get the interference even when parked up. The charger has a graphite core on it all ready, but I tried adding another - to no avail. Doesn't matter which socket I use either or whether I use a permanent or ignition live.
18th Jan 2012 10:38pm |
What happens if you ground directly from the charger into a ground point in the boot? |
19th Jan 2012 7:04am |
Kaboom! probably I'll give it a try and report back. .
19th Jan 2012 8:21am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
replace the battery ... ... - .- -.
19th Jan 2012 8:27am |
Leaking front airbag |
19th Jan 2012 9:03am |
Both .
19th Jan 2012 4:19pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 |
Remove the netbook charger and leave at home? Discovery 4 HSE
19th Jan 2012 4:56pm |
Thanks RRUK This is for my carpc so need it
19th Jan 2012 6:01pm |
try different ciggy sockets cos the one you are trying might not shielded.... ... - .- -.
19th Jan 2012 6:19pm |
I get the hiss and interference from all power sockets and from the ignition live I have in the boot. I find myself an inverter and try that out as a last resort. All other sound sources are just fine, it only affects the radio, which I might be able to overcome using my dvb-t stick for radio reception, or I can introduce a switch to turn off the supply when the carpc is not needed. .
20th Jan 2012 4:53pm |
