Home > Technical (L322) > Drivers door Lock
Andpopse
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Drivers door Lock
I recently changed the door handles (due to the usual surface finish wear) . Everything works fine but the manual key lock (Driver door) does not operate. I assume i have not located the rod properly. Its too cold to go and investige, so i wondered if any of you kind folks have any thoughts.
Thanks
Andy
Post #101833 15th Jan 2012 5:05pm
Andpopse
Sorted ! There is a hole that the 4 pronged rod was not located in. Also fitted my damped tailgate bits from Dan, easy job.
Post #102946 22nd Jan 2012 2:50pm
