Home > Technical (L322) > Drivers door Lock |
Andpopse Member Since: 16 Oct 2010 Location: Bristol Posts: 100 |
I recently changed the door handles (due to the usual surface finish wear) . Everything works fine but the manual key lock (Driver door) does not operate. I assume i have not located the rod properly. Its too cold to go and investige, so i wondered if any of you kind folks have any thoughts.
15th Jan 2012 5:05pm |
Sorted ! There is a hole that the 4 pronged rod was not located in. Also fitted my damped tailgate bits from Dan, easy job. |
22nd Jan 2012 2:50pm |
