Home > In Car Electronics (L322) > [Closed - Not Solved] Radio Interference from Laptop Charger
If I plug my netbook charger into the car, it disrupts the radio signal like the radio is struggling to find or stay tuned to a station, like the diversity function has stopped working. Not related to engine speed so don't think it is a ground loop problem. When unplugged the radio is clear as a bell and diversity works well. Get the interference even when parked up. The charger has a graphite core on it all ready, but I tried adding another - to no avail. Doesn't matter which socket I use either or whether I use a permanent or ignition live.
So is it a crappy charger or is there a way to avoid this interference? (it is a 12v adapter charger not on an inverter)
Thanks Question .
Post #102346 18th Jan 2012 10:38pm
What happens if you ground directly from the charger into a ground point in the boot?
Post #102366 19th Jan 2012 7:04am
Kaboom! probably Smile I'll give it a try and report back. .
Post #102374 19th Jan 2012 8:21am
replace the battery ... Mr. Green ... - .- -.
Post #102375 19th Jan 2012 8:27am
Leaking front airbag Whistle
Post #102377 19th Jan 2012 9:03am
Both Rolling with laughter Rolling with laughter Rolling with laughter .
Post #102446 19th Jan 2012 4:19pm
Remove the netbook charger and leave at home? Discovery 4 HSE
Post #102455 19th Jan 2012 4:56pm
Thanks RRUK Wink This is for my carpc so need it Smile
Tried earthing the adapter when plugged in no difference to interference. Do I wrap the adapter block in lead? (dons balaclava and heads off to local church.......) Smile .
Post #102472 19th Jan 2012 6:01pm
try different ciggy sockets cos the one you are trying might not shielded.... ... - .- -.
Post #102480 19th Jan 2012 6:19pm
I get the hiss and interference from all power sockets and from the ignition live I have in the boot. I find myself an inverter and try that out as a last resort. All other sound sources are just fine, it only affects the radio, which I might be able to overcome using my dvb-t stick for radio reception, or I can introduce a switch to turn off the supply when the carpc is not needed. .
Post #102669 20th Jan 2012 4:53pm
