Home > In Car Electronics (L322) > BM54 Reference
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
BM54 Reference
I know this is a regular and probably boring topic, but:
Seeing as the BM54 upgrade looks like the only possibly way of getting an aux socket for MP3 playback in my MY06 FFRR (was thinking of the Intravee route but apart from the fact that allegedly they're discontinued, I also think they're for pre-touchscreen models?) - anyway:
are either of these the right units to work on the RR and to provide the aux socket input?
http://www.ebay.co.uk/itm/BMW-BM54-SAT-NAV...1c22c1f867
or
http://www.ebay.co.uk/itm/Genuine-BMW-E46-...3a6eedf285
Don't outbid me now!!
Thanks.
Post #101771 15th Jan 2012 1:10am
daveo
the first units has pre OUT for an extra amp,its not a aux in...the second one looks right as you want a B54 from a bmw as they had the aux in on them, but you are better off asking the seller if it has the aux in ...
cant tell from the pins but if it had the plug still in the back you can see the extra plug... V8 facelift Range Rover Autobiography 22" wheels.
Post #101790 15th Jan 2012 12:03pm
Neither units will allow aux input.
The top unit is a standard BM54 radio tuner modified with pre-amp outputs fitted to overcome the common output channel failure.
The bottom unit is a standard BM54 radio tuner.
Both will fit an L322 non-touch screen, the first will need to be fed thro an external amp, the second is a direct replacement.
Need to check both to see if they are square or round pin.
Post #101791 15th Jan 2012 12:04pm
Cappo
OK thanks, I'll have to keep looking.
It's really frustrating not being able to play MP3s. I do have an FM modulator but I'm in Europe quite a bit and it seems you get a lot more interference over there so you're forever retuning.
Post #101793 15th Jan 2012 12:30pm
Don't know if its possible on the MY06, but if you have a cassette tape behind the screen, you could simply tap into the tape audio wires like I have for my carpc:
http://www.fullfatrr.com/forum/post96334.html#96334
This is on the old non touch screen though with cassette tape, and you won't get any playback info. .
Post #101805 15th Jan 2012 1:13pm
Cappo
I don't think there's a cassette anywhere (I used to do that in the old P38) but there's no reference to it on the screen and I've never found anything which tilts out to get to a tape drive, thanks though.
Post #101809 15th Jan 2012 1:37pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Both listing are or were for BMW BM54 tuners BUT both are earlier versions without the aux input function. Exclamation Exclamation You can tell the age of the tuner from the part number label. The 'KW' number gives the build week and year - in both cases week 51 of 2002.
I cant remember exactly when they changed but it was around late 2003 so to be on the safe side find one with KW:**/04 or newer Thumbs Up
Here's one for you: (see label in the second picture)
http://www.ebay.co.uk/itm/180786393214
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #101840 15th Jan 2012 6:44pm
Ajay(UK)
Cappo Exclamation Exclamation Exclamation Exclamation
I've just clicked on your model and you state yours is a 2006 FFRR Shocked
BM54 tuners are only compatible with pre-touchscreen models 2002-2005 - thats why you cannot find a cassette player Rolling Eyes
Post #101841 15th Jan 2012 6:49pm
daveo
thats a good reference point Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #101842 15th Jan 2012 6:52pm
SteveMFr
Site Sponsor
Andy.
This is exactly what I was thinking all along - you guys aren't reading what he wrote and he's going to end up buying a BM54 for a touchscreen RR!
The best choice for oem style integration is the LR audio connectivity module. It is actually listed for the post 07 models but it will work fine on your 06. You have to remove the dash to get at the back of the head unit for the install tho. Not too bad. Do a search. Been covered several times.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #102010 16th Jan 2012 9:48pm
L4FLIROP
United States 2003 Range Rover HSE 4.4 V8 Adriatic Blue
I have an IntraveeII and an Alpine 420i for sale if you are interested
Post #105810 7th Feb 2012 2:40am
