Home > General > Heathrow Terminal 4 Short Term Car Park
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
Has anyone taken a FFRR into the Heathrow Terminal 4 Short Term Car Park? BAA quote 2m clearance, but there is nothing like a report from someone who has done it. I plan to lower the suspension and lock it.
I hit the roof of my Disco 3 in the Gatwick North short term on the entry height banner and avoid multistories now as much as I can.
I have no issue with the terminal 5 multistory as I guess when they designed it they considered the fact a few visitors would be in large 4x4 and people carriers and provided 2.5m clearance! 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #6664 4th Aug 2009 7:47pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
A FFRR is 1913 mm tall in off-road height and 1863 at standard, so a 2m barrier should be no issue at all.
If you're unsure, stop at the height barrier and have a quick look ... Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #6672 5th Aug 2009 12:33am
claud
Mick
Thanks for the stats. I am hopeful it is not going to be an issue, still smarting from the scratched rear door on my Disco 3!
Still like to hear from someone who has actually driven in that multistory with a FFRR.
Paul 2018 Range Rover Autobiography
1959 Series II
Post #6678 5th Aug 2009 9:00am
Vogue
I remember going onto a multistory car park 25 years ago with a Land Rover. The height barriers were OK, but they didn't take account of the newly fitted fluorescent tubes fixed to every concrete cross beam.
Once in, there was no way to reverse out, only option was to drive forward and take out quite a few light fittings -needless to say I haven't revisited. Well it was their fault - their height warnings were inaccurate....
and talking to a few friends this is a fairly common occurance - so ignore the height barriers and make your own judgement - I prefer to keep an eye out through the glass sunroof and drive slowly.
Post #6679 5th Aug 2009 9:06am
Larry
England 2006 Range Rover SE Td6 Java Black
Incorrect height barriers does seem to be the norm. In a local shopping centre the signs were correct, but they added new hanging signs in the car park. There was luckily enough clearance for the RR, but I always go in there in access mode (locked) anyway.
Not practical to do this at Heathrow, but when in doubt, I usually take the missus' car the first time I go somewhere with a height limit and have a look out for other FFRR's or similar in the car park.
Post #6682 5th Aug 2009 11:25am
