![]() | Home > Technical (L322) > suggestions for tow bar |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
Hi all - having just got rid of my wires P38 for A FORD KUGA I now need to get a tow bar for either hers or mine. preferably mine (although I don't tow much) but have a small trailer that we use for the "Tip run" every so often.
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
Hi Ashley
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
www.pfjones.co.uk do a range of options for towbars (inc the OE Westfalia model) as I couldnt stomach the £££ for an OE one, just so I could carry a bike on the back cheers
You have a pm. |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
fisha isn't quite right. You need:
My last L322 was towbar-less. eBay is your friend.
im just adding electrics to my 04 FFRR
You need the control unit as well |
ok, cheers, will get a few quotes before I pull the trigger on the electrics and the ECU cheers
towequipe is the cheapest normally, they sell westfalia removable kits (they manufacture them for Land Rover) at around half the price of the Stealers and they come with the holder in the boot and everything you get in a Land Rover box...
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
I had the armature, twin electrics, towing module all supplied and fitted at the dealer for £523.61 inc Vat. Not bad I thought.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Im so glad mine came with one fitted! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Noooooo, i recieved the 13pin westfalia towbar electrics from towequipe. This included everything you need inc the control module. |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 742 ![]() ![]() |
I bought this one http://www.ebay.co.uk/itm/140569051959#ht_1568wt_1396
