Home > Technical (L322) > suggestions for tow bar
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi all - having just got rid of my wires P38 for A FORD KUGA I now need to get a tow bar for either hers or mine. preferably mine (although I don't tow much) but have a small trailer that we use for the "Tip run" every so often.
I need a small profile one as I don't have much length in the garage for it to be sticking out the back too far or a removable one.
Where's the best place to look and at what. Don't want to spend too much as we don't use it that often. Will I need just a tow ball (i.e. does the FF already have the gubbins underneath and I assume electric harness is already routed and just need plugging in.??
So many questions.. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #99509 28th Dec 2011 9:45am
piecost76
Hi Ashley
All I can say is that the genuine set comes in at an eye watering £500 excl electrics!
Which is why I want one with towbar already fitted!
Hold onto your pants!
Ivor Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #99512 28th Dec 2011 10:38am
fisha
the RR, you really need 2 parts ...
The towbar
The electrics
the electrics is a loom plus a few ECU boxes which simply plug into existing connectors around the rear boot area of the car. Its a fairly simple thing to fit. I got mine directly from the dealer a few years around ... was about the same price as online places, so I figured better to get it from LR direct to know it would work without issue.
the towbar can be had directly from LR ( £££ ), or from other manufacturers onine ( less £££, more like ££ Laughing ) I have a witter one which is fixed and does stick out a bit. Westfalia do a removable towbar similar to the LR one. Google them online for the best deals. Fitting them is not horrendous and can be done at home without too much fuss. I had to remove the rear bumper. Sounds daunting but it wasn't that bad and done in an afternoon from start to finish.
Unbfortunately, there is no cheapo cheapo option ... the car is rated to tow 3.5ton, so anything you get for the RR is going to be made to meet that spec ... even it is only a basic trailer on the back.
I do sometimes wish I had gone for a removable one ... it does stick out and I notice it when i'm not towing. V8 or else ...
Post #99523 28th Dec 2011 1:39pm
bogie
www.pfjones.co.uk do a range of options for towbars (inc the OE Westfalia model) as I couldnt stomach the £££ for an OE one, just so I could carry a bike on the back cheers
bogie
Post #99536 28th Dec 2011 2:54pm
You have a pm.
Post #99539 28th Dec 2011 3:06pm
A1GSS
fisha isn't quite right. You need:
Towing Armature (to suit your model year)
Towing electrics
Towing ECU (not sold with the electrics)
Tow ball of choice (detachable or multi height)
If you PM Dan he'll get you a good price. Plenty of third party ones available but I;d recommend you use the dedicated GENUINE electrics for the few extra quid they cost. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #99541 28th Dec 2011 3:10pm
dan_uk_1984
My last L322 was towbar-less. eBay is your friend.
There are often complete sets advertised for around £250.
These are the last prices I paid:
Towing Armature (to suit your model year) - £50
Towing electrics - £25
Towing ECU (not sold with the electrics) - £65
Tow ball of choice (detachable or multi height) - Multi-height, Home-made.
If you need something instantly then you will have to buy from a dealer or equiv. If you dont mind waiting a few weeks then set a favourite search going on eBay and buy the bits separately.
Post #99543 28th Dec 2011 3:17pm
bogie
im just adding electrics to my 04 FFRR
just to be clear - if I buy the OE Westfalia dedicated electrics kit - 7 pin/£100 ish do I still need to buy the "towing ECU" for £65 as well ? or does this come with the electrics and you only need it if you buy the cheaper aftermarket non dedicated electrics kit ?
Ive read the Westfalia manual and it refers to a "tow control unit" but dosent say you need to buy one....
/most confusing cheers
bogie
Post #99815 30th Dec 2011 3:30pm
You need the control unit as well Smile
£100 is steep for the electrics. My 12s/n sockets and cable from Sam were a lot less than that Wink
Post #99819 30th Dec 2011 4:30pm
bogie
ok, cheers, will get a few quotes before I pull the trigger on the electrics and the ECU cheers
bogie
Post #99821 30th Dec 2011 4:42pm
towequipe is the cheapest normally, they sell westfalia removable kits (they manufacture them for Land Rover) at around half the price of the Stealers and they come with the holder in the boot and everything you get in a Land Rover box...
Craig Thumbs Up
Post #99889 31st Dec 2011 2:19am
AMD
I had the armature, twin electrics, towing module all supplied and fitted at the dealer for £523.61 inc Vat. Not bad I thought.
Picked up the multi height ball on eBay for £65.00 Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #99907 31st Dec 2011 1:18pm
Andy
Im so glad mine came with one fitted! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #100220 3rd Jan 2012 11:13pm
T24RES
/most confusing
Noooooo, i recieved the 13pin westfalia towbar electrics from towequipe. This included everything you need inc the control module.
Post #100266 4th Jan 2012 3:01pm
Johnte
I bought this one http://www.ebay.co.uk/itm/140569051959#ht_1568wt_1396
everything needed was included for less than £80 including postage.. If you 'click' the link on their site, it will show you the fitting instructions (where everything goes)
Very simple to fit Thumbs Up Thumbs Up
Post #100382 5th Jan 2012 12:27pm
