Home > Maintenance & Mods (L322) > Range Rover Daylight Running Lights
Page 2 of 3 <123>
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
scarey
do you have a pic of your lights
Post #99073 23rd Dec 2011 12:18pm
Googsy
kingpleb wrote:
Wayne Wover is my thoughts Smile
Never liked DRL's and could never see why we don't employ the same methods as other euro countries that require lights during the day all year round.... a £5 relay in a certain position in the car puts the lights on when the engine is running... simples Smile
More like Ben Dover to me Laughing Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #99074 23rd Dec 2011 12:19pm
T24RES
nicedayforit wrote:
I suspect the fitment shown on the RR in the picture may not conform to the legal requirements for the fitting of DRL's. The maximum distance they may be fitted is 450mm from the outer edge of the car which on a RR is almost exactly where the fog lights are.
I would check with the suppliers if you decide to order.
They would look better if they were circular.
I think you'll find that these come under optional/additional lamps and not obligitory (think truckers 10 x daylighter spotlamps). As such are not included in the Con & use regs for this age of car.
Post #99214 23rd Dec 2011 10:52pm
Not quite true, daylight running lights are now included in an update to the Vehicle Lighting Regulations 1989.
Post #99235 24th Dec 2011 9:37am
dannyp15 wrote:
scarey
just imagine leds in the fogs ...i could take a pic but with cameras having different colour tolerances it probably wont reproduce the 'right' picture.. ... - .- -.
Post #99237 24th Dec 2011 9:51am
@Scarey
Just curious, I agree you have effectively removed your non-obligatory front fog lights and replaced them with drl's but have you ever been pulled by plod for having your "foglights" on during the day?
Best solution I've seen for drl's on a RR.
Post #99241 24th Dec 2011 10:02am
never been pulled..if i did then i would point out that fogs need the sides lights to be on to work and the fact that mine are not on would put me in the clear..i rest my case your 'onour.. Mr. Green
one point , to avoid a dash error for the now defunct fogs you need to put resisters on the fogs.. ... - .- -.
Post #99242 24th Dec 2011 10:12am
The only thing I could think you might have a problem with is that by putting an led lamp in the existing fitting, the combination of lamp and fitting is not "E" marked and thefore not strictly legal. Although I think someone would have to be very keen to spot that.
Do you disconnect them for mot?
Post #99243 24th Dec 2011 10:17am
just had a mot and as its not a legal requirement to have front fogs ,it passed ..in fact the mot bloke commented on how noticeable my range was [because of the lights] when they drove it into the mot station.. ... - .- -.
Post #99244 24th Dec 2011 10:23am
Might have a look into that in the New Year, particularly as it's easily reversible without damaging the car. Thumbs Up
Post #99247 24th Dec 2011 10:33am
I have xenon DRL's by fitting a xenon kit in the fogs and using a five pin relay...As soon as you switch on the lights (side or main or auto) they turn off...
Plus they have their power taken from a source that stays live for 35secs after the key turns off so i can see my way home in the dark!
Did'nt want an add on lamp, as most look horrid IMO (take a look at the 2012 DRL's in the 322) so went the factory look way...
Craig Thumbs Up
Post #99248 24th Dec 2011 10:34am
them xenons must be pretty bright craig , i've found that my 18 smd's are enough...the beauty of using a dedicated drl switch is that they still stay on with the sides so on days where the bright headlight xenons are to much ,you have the sides and drls.. ... - .- -.
Post #99250 24th Dec 2011 10:41am
Thy are a bit Stan if im honest! I fitted LED bulbs and they were hardly noticable Crying or Very sad So i went the Xenon route... Wish i could find a LED bright enough!
Craig Thumbs Up
Post #99253 24th Dec 2011 10:51am
daveo
same here, i have LEDs in my fogs and it went through the mot fine, yes LEDs dont throw that much light but look fine for DRL's, I changed my high beam to LEDs but they were no good at all so swapped them to a xenon kit giving me tri-xenons never said any thing about them in the mot ether. V8 facelift Range Rover Autobiography 22" wheels.
Post #99258 24th Dec 2011 11:32am
so how well are these instant xenon main beams working then dave? ... - .- -.
Post #99268 24th Dec 2011 1:35pm
Page 2 of 3 <123>
