![]() | Home > Maintenance & Mods (L322) > Range Rover Daylight Running Lights |
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
scarey
More like Ben Dover to me ![]() Gone Audi A5 2.7TDI Gone Discovery 3 HSE Gone Mercedes CLK Gone Range Rover 2.5 DSE |
Not quite true, daylight running lights are now included in an update to the Vehicle Lighting Regulations 1989. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35504 ![]() ![]() |
just imagine leds in the fogs ...i could take a pic but with cameras having different colour tolerances it probably wont reproduce the 'right' picture.. ... - .- -. Y. O. L. O. . |
@Scarey
never been pulled..if i did then i would point out that fogs need the sides lights to be on to work and the fact that mine are not on would put me in the clear..i rest my case your 'onour.. |
The only thing I could think you might have a problem with is that by putting an led lamp in the existing fitting, the combination of lamp and fitting is not "E" marked and thefore not strictly legal. Although I think someone would have to be very keen to spot that.
just had a mot and as its not a legal requirement to have front fogs ,it passed ..in fact the mot bloke commented on how noticeable my range was [because of the lights] when they drove it into the mot station.. ... - .- -.
Might have a look into that in the New Year, particularly as it's easily reversible without damaging the car. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
I have xenon DRL's by fitting a xenon kit in the fogs and using a five pin relay...As soon as you switch on the lights (side or main or auto) they turn off...
them xenons must be pretty bright craig , i've found that my 18 smd's are enough...the beauty of using a dedicated drl switch is that they still stay on with the sides so on days where the bright headlight xenons are to much ,you have the sides and drls.. ... - .- -.
Thy are a bit Stan if im honest! I fitted LED bulbs and they were hardly noticable |
same here, i have LEDs in my fogs and it went through the mot fine, yes LEDs dont throw that much light but look fine for DRL's, I changed my high beam to LEDs but they were no good at all so swapped them to a xenon kit giving me tri-xenons never said any thing about them in the mot ether. V8 facelift Range Rover Autobiography 22" wheels.
so how well are these instant xenon main beams working then dave? ... - .- -.
