![]() | Home > General > VOSA MOT Manual 2012 |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Issue date 1st January 2012 available here
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 741 ![]() ![]() |
Are there any major differences ? I notice the tow bar / electrics now look to be part of MOT - is this new? (Sorry, I'm not a MOT tester, and never saw the old manual) |
Tow bar and electrics came into the MOT a couple of years ago |
Shows how much I know about it |
The new requirement for tow bar electrics require 13pin sockets to be tested for correct operation of each of the pins by use of a plug-in tester.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6745 ![]() ![]() ![]() |
Interesting section on TPMS. It seems to indicate older cars (pre 1st January 2012 won't be failed it TPMS is displaying a fault? :-
Still good news on the diesel cat front as its still just a visual inspection which is great for the people who de-cat via the broomstick method |
Sea Aitch Member Since: 17 Feb 2011 Location: Hertford Posts: 120 ![]() ![]() ![]() |
The way I read it, is that it is only necessary to have a CAT fitted on a vehicle that requires a CAT test, and this test only applies to spark (non diesel) engines. Assuming I'm right, it doesen't matter whether you use the "broomstick" method, or take away the CAT altogether and replace it with a decat section as long as the exhaust is supported properly and there are no leaks.
^^^^^ +1 |
