Home > General > VOSA MOT Manual 2012
Issue date 1st January 2012 available here
Warning, large PDF file...
Post #97949 16th Dec 2011 8:48am
Good man, thanks for listing... Interesting they have not made HID light washers a requirement as was indicated may happen this time...
Craig Thumbs Up
Post #97954 16th Dec 2011 9:56am
Johnte
Are there any major differences ? I notice the tow bar / electrics now look to be part of MOT - is this new? (Sorry, I'm not a MOT tester, and never saw the old manual)
Post #97957 16th Dec 2011 10:23am
Tow bar and electrics came into the MOT a couple of years ago
Post #97960 16th Dec 2011 10:38am
Johnte
Shows how much I know about it Embarassed Embarassed
Any other changes in the new manual to be worried about ?
Post #97963 16th Dec 2011 10:42am
The new requirement for tow bar electrics require 13pin sockets to be tested for correct operation of each of the pins by use of a plug-in tester.
12N and 12S sockets are not to be tested for correct operation they have just to be "looked at" to insure they are in a serviceable condition.
The requirement for the towbar itself is as introduced a few years ago.
Post #97964 16th Dec 2011 10:50am
Interesting section on TPMS. It seems to indicate older cars (pre 1st January 2012 won't be failed it TPMS is displaying a fault? :-
The inspection of the tyre pressure monitoring system (TPMS) warning lamp only applies to passenger vehicles with:
four or more wheels, and
not more than 8 passenger seats excluding the driver’s seat, and
first used on or after 1 January 2012
The check does not apply to quadricycles.
The TPMS warning lamp (as below) will generally illuminate and go off again when the ignition is switched on. If one or more tyre pressures are low, the lamp will remain illuminated.
In the event of a system malfunction, the lamp will flash a number of times and then remain on. Got - 2017 SDV8 Autobiography in Loire Blue
Post #97969 16th Dec 2011 11:58am
Still good news on the diesel cat front as its still just a visual inspection which is great for the people who de-cat via the broomstick method Smile
Post #97988 16th Dec 2011 2:42pm
Sea Aitch
England 2007 Range Rover Vogue SE TDV8 Zermatt Silver
The way I read it, is that it is only necessary to have a CAT fitted on a vehicle that requires a CAT test, and this test only applies to spark (non diesel) engines. Assuming I'm right, it doesen't matter whether you use the "broomstick" method, or take away the CAT altogether and replace it with a decat section as long as the exhaust is supported properly and there are no leaks.
Method of Inspection
"On vehicles that qualify for a full cat emissions test, check the presence of the catalytic converter."
Reason for Rejection
"A catalytic converter missing where one was fitted as standard"
Colin
Post #98006 16th Dec 2011 4:17pm
^^^^^ +1 Thumbs Up
Post #98007 16th Dec 2011 4:23pm
