Home > In Car Electronics (L322) > Number Plate bulbs
markdotreed
Number Plate bulbs
My wife has just text me to say that a warning light has come on to 'check the Number plate bulbs'
Is there such a thing and is it as simple as buying a couple of bulbs??
tas
M Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #96618 7th Dec 2011 3:37pm
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
just something silly but have you checked if the bulbs work ? just put your lights ok, check if both dont work or one does, change if need be, if they are both not working it might be a loose wire etc.
TBH the RR's just act nuts in the winter, they dont like low temps and start acting crazy and become ok later on.
sure others will be round soon to offer advise.
Post #96621 7th Dec 2011 4:10pm
Yip, they sit in the lower part of the upper tailgate, either side of the button you press to release the latch and lift the tailgate up.
replacement procedure should be in the hand book or they may simply have a screw at each side for release.
Post #96622 7th Dec 2011 4:10pm
markdotreed
I'm not at home and won't be back until after dark. I was not aware that there was a warning for them not working. I think the part number is CZQ000010 and they seem common enoguh.
As usual there is no answer to any of the phones so I can't ask her to check Regards
Mark
Post #96623 7th Dec 2011 4:18pm
Reformed
Yes there is a warning on them. Mine came on when I changed them to the led type.. They were on, but the error came up. Reformed
Post #96669 7th Dec 2011 7:16pm
markdotreed
I had a bulb in an old defender bulb kit I had kicking around so have changed it (althought I have ordered an L322 bulb kit from Dan as well)
Piece of pi$$ changing it though. Not even screwed in... 2 second job. Regards
Mark
Post #96681 7th Dec 2011 8:39pm
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
its easy to replace, the lense just pops out by using a small screwdriver of similar blunt tool and you then have access to the bulb. 1 min job then clip lense back in. Range rover td6 54 reg touch screen
Post #96689 7th Dec 2011 9:57pm
EVOeng
You may as well replace them with the LEDs. There was a thread on them a few weeks back.
Post #96837 9th Dec 2011 1:56pm
