![]() | Home > In Car Electronics (L322) > Number Plate bulbs |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 ![]() ![]() |
My wife has just text me to say that a warning light has come on to 'check the Number plate bulbs'
Yip, they sit in the lower part of the upper tailgate, either side of the button you press to release the latch and lift the tailgate up.
I'm not at home and won't be back until after dark. I was not aware that there was a warning for them not working. I think the part number is CZQ000010 and they seem common enoguh.
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Yes there is a warning on them. Mine came on when I changed them to the led type.. They were on, but the error came up. Reformed |
I had a bulb in an old defender bulb kit I had kicking around so have changed it (althought I have ordered an L322 bulb kit from Dan as well)
tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90 ![]() ![]() ![]() |
its easy to replace, the lense just pops out by using a small screwdriver of similar blunt tool and you then have access to the bulb. 1 min job then clip lense back in. Range rover td6 54 reg touch screen |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 ![]() ![]() ![]() |
You may as well replace them with the LEDs. There was a thread on them a few weeks back. |
