Home > General > Snow chains
rwilson
United Kingdom 2009 Range Rover Vogue TDV8 Zermatt Silver
Snow chains
Hi, just read the Handbook re fitting chains. LR say fit to rears only not fronts. I was under the impression that with permanent 4 wheel drive you would fit to front to give more steerage. In my old a4 Quattro I used to fit them to the fronts.....maybe I shouldnt Have!!!!!!!!
Does anyone know why you fit to rears only, can't be to do with arch clearance?
Ps just needed to know ahead of ski trip not 1/2 way up the mountain at 0700 am!
Post #96524 6th Dec 2011 8:24pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Cant remember what but the catch something, might be a brake line. 3 year ago we needed them to get in to Zurs. letters not necessarily in the right order
Post #96525 6th Dec 2011 8:27pm
ebajema
The reason could be that if the rear wheels start to slide the car can start spinning very easily and when the front wheels start sliding (while the rear still have grip) that won't happen. Someone showed it to me with a toy car years ago and it was an eye opener. That is the reason why rear wheel driven cars are harder to control in slippery conditions because of the spinning as well.
I would still prefer to be driving with chains on all four wheels or studded tires like in Scandinavia (but illegal in a lot of other countries), apart from the work to get them on (the chains).
I do have to say, I never checked above with any experts (never went for the skid courses in Holland).
I loved driving rear wheel drive cars in the snow, hooning like crazy in parking lots. The Herald, Beetle, Alfa's were great for that. Now I am a sedate driving gentleman (with no snow in site), until my right foot gets "cramp" and floors the accelerator of course Whistle Twisted Evil MY 2010 5.0 SC Galway green and sand interior!!
Post #96527 6th Dec 2011 8:34pm
I think its more to do with the same thinking as fitting newer tyres to the rear, They can dig in more and slow you down and avoid the car spinning round on it self (ie a 180/90' spin) and gives the average driver more control in poor coniditions.
if the weather is that bad you need to use snow chains on a FFRR then you should be getting snow and ice tyres fitted as well as they will give a better chance of getting further without having to fit said chains Very Happy
Post #96528 6th Dec 2011 8:35pm
dan_uk_1984
With chains fitted you cant go fast anyway, so steering is less of a problem than maintaining forward momentum...
Also when the front under-steers in snow if you apply a lot of lock it will steer the car using the brakes - part of the DSC logic. If you find yourself really in need of turning, it may sound counter intuitive, but brake. This kicks the CBC (corner braking control) into action and will drag you into a turn by whatever means possible.
When it snows it's certainly worth playing in the car park & on safe hills etc to make sure you know exactly how the car handles. Also how to use the safety systems to your advantage...
Post #96529 6th Dec 2011 8:38pm
rwilson
Thanks for the ideas all of which make sense. I've come from a karting background where it's all about front end grip, once you are mid corner you just sort out the balance on the exit, however I guess too much front end does mean it will swap ends quicker so I guess that maybe LR's thought process!
Difficult one though, terminal under steer or swaps ends in milli second.........guess I could always drive slower, lol
Post #96540 6th Dec 2011 9:20pm
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Land Rover supply a snow traction system for 20 inch wheels only to fit on the front wheels and snow chains for 18 and 19 inch wheels to fit on the rear wheels, go figure.
http://www.landrover.com/gb/en/rr/range-rover/accessories/
Post #96541 6th Dec 2011 9:20pm
you could consider these..
http://www.fullfatrr.com/forum/topic8539.html
Post #96544 6th Dec 2011 9:22pm
rwilson
I have the traction system aka spikes spider alpine pro.
More investigation needed!!!!!
Post #96545 6th Dec 2011 9:25pm
dan_uk_1984
The DSC will always do its best to prevent the back end stepping out. The only time I had the RR properly sideways was on the M4. It was closed at the time due to all the snow, I just drove round the cones... Whistle 70mph on 4 inches of snow/ice probably wasn't the best plan.
I find the trouble with the RR is not the slide, it's the recovery of the slide. It has one hell of a pendulum effect when the rear end gets shifting!
Post #96546 6th Dec 2011 9:25pm
rwilson
Had a feeling snow socks weren't allowed in France past the signs where snow chains must be mandatorily carried, but might be wrong.
Post #96548 6th Dec 2011 9:28pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Autosocks Snow Socks have recently been authorised for France. A certificate can be downloaded from the Autosocks website.
I got a pair. Was going to use them on the fronts in case of need but after reading the above thought maybe the rears would be better. Any thoughts? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #96549 6th Dec 2011 9:31pm
the way you drove on the plain i dont think you need any thing on your wheels Laughing
Post #96551 6th Dec 2011 9:37pm
rwilson
Thanks to csk's post the LR traction system is fitted to the fronts so that's way I' ll go.
Trust your instincts!!
Post #96553 6th Dec 2011 9:39pm
Nomad
I did plenty of sideways stuff! Could have done with the Socks there! Are they authorised? Wink 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #96554 6th Dec 2011 9:41pm
