![]() | Home > General > Snow chains |
rwilson Member Since: 17 Jan 2011 Location: London Posts: 84 ![]() ![]() ![]() |
Hi, just read the Handbook re fitting chains. LR say fit to rears only not fronts. I was under the impression that with permanent 4 wheel drive you would fit to front to give more steerage. In my old a4 Quattro I used to fit them to the fronts.....maybe I shouldnt Have!!!!!!!!
The reason could be that if the rear wheels start to slide the car can start spinning very easily and when the front wheels start sliding (while the rear still have grip) that won't happen. Someone showed it to me with a toy car years ago and it was an eye opener. That is the reason why rear wheel driven cars are harder to control in slippery conditions because of the spinning as well.
I think its more to do with the same thinking as fitting newer tyres to the rear, They can dig in more and slow you down and avoid the car spinning round on it self (ie a 180/90' spin) and gives the average driver more control in poor coniditions.
With chains fitted you cant go fast anyway, so steering is less of a problem than maintaining forward momentum...
Thanks for the ideas all of which make sense. I've come from a karting background where it's all about front end grip, once you are mid corner you just sort out the balance on the exit, however I guess too much front end does mean it will swap ends quicker so I guess that maybe LR's thought process!
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
Land Rover supply a snow traction system for 20 inch wheels only to fit on the front wheels and snow chains for 18 and 19 inch wheels to fit on the rear wheels, go figure.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35540 ![]() ![]() |
you could consider these..
I have the traction system aka spikes spider alpine pro.
The DSC will always do its best to prevent the back end stepping out. The only time I had the RR properly sideways was on the M4. It was closed at the time due to all the snow, I just drove round the cones... ![]() I find the trouble with the RR is not the slide, it's the recovery of the slide. It has one hell of a pendulum effect when the rear end gets shifting! ![]() |
Had a feeling snow socks weren't allowed in France past the signs where snow chains must be mandatorily carried, but might be wrong. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Autosocks Snow Socks have recently been authorised for France. A certificate can be downloaded from the Autosocks website.
the way you drove on the plain i dont think you need any thing on your wheels |
Thanks to csk's post the LR traction system is fitted to the fronts so that's way I' ll go.
I did plenty of sideways stuff! Could have done with the Socks there! Are they authorised? |
