Home > Technical (L322) > Air Con - Not cold
jonny142
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Air Con - Not cold
If you ever needed the aircon to work properley, today is the day.
Turned mine on and I could hear the gas. Looks like its working properly but Not Cold !!!
Any ideas chaps
Cheers
Jonny 4.4 V8 Vogue Adriatic - Cream leather
Post #6309 1st Jul 2009 6:20pm
dan_uk_1984
Generally if you can hear a hissing noise there isn't enough gas in the system for it to work properly (although there may be enough not to have triggered the low pressure switch)
Get off to KwikFit where they do a 10% cooler or your money back deal, obviously if it just needs a top up then great, if it's something else then you won't have to pay. They should be able to detect any leaks in the system.
Don't waste time with the kits from Halfords, but you could pop it down there to check and see what the level is....
Dan
Post #6310 1st Jul 2009 9:02pm
Larry
England 2006 Range Rover SE Td6 Java Black
Dan
Disagree. Have used the refill aerosols in the past from Halfords (albeit not on a RR) on recommendation from a professional aircon engineer I know. Bloody excellent. Worked a treat and only cost circa £11.
He said that you're wasting your money on the ones with a gauge on though. Probably a good idea to do regularly anyway as it tops up the lube in the gas.
Jonny, if you don't already know this, you should run up your aircon at least 10 mins every week to keep the seals in the system and the bearings operating correctly, otherwise you will lose gas through the seals at a far higher rate than normal (there is always some leakage, which is why you need to top it up every few years). It may even say something similar in the handbook.
Automotive aircon types will generally suggest that they fill up the system with a UV dye and that you come back to see if there is a leak. I don't think the extra cost is worth it unless the car is relativley new or has recently been regassed then stopped working.
Post #6316 2nd Jul 2009 10:50am
dan_uk_1984
The cans in Halfords will not evacuate the system first though so you will just be pumping more stuff in, rather than sucking it all out and then refilling with the correct amount. If you have a leak this will not be detected, the professional machines create a strong vacuum and then measure any drop in vacuum signifying a leak before filling.
If you don't get the ones with the gauge on, you run the risk of over filling, then the system will over pressurize and blow the condenser or evaporator seams. You could also overfill with oil, which will just destroy the compressor.
The cans that have the appropriate quantity in Halfords are £39.99, where as it's £60 at kwikfit for the complete proper service where they will also inject leak dye, the correct amount of oil, and the correct amount of refrigerant.
If a job's worth doing it's worth doing right.
Post #6317 2nd Jul 2009 11:19am
Martin
Site Admin
The AC cans with the gauge which Halfords sell for £40 can be had from eBay for about £23. Smile
Post #6319 2nd Jul 2009 12:04pm
Larry
Dan, while I agree that you have a point about doing the job correctly, my air con man reckons (rightly or wrongly) that you can't over presurise the system with the aerosol cans as they don't operate at high enough pressures and that the system will fill up and then no more will go in beyond the operating pressure of the can. It was only recommended as a quick fix to get it working again, rather than to ensure you had the A/C operating at peak performance, but I can confirm that it works well enough - I did have doubts until then - and had no detrimental effect to the system (well, not in 5 years anyway!). Just an aside, I'm sure there will be an over pressure relief valve to prevent blowing up the system.
And, yes, if you have a leak, the aerosol can will at best give you a few days/weeks operating and you'll be back to square one. My point is that air con systems naturally all leak off over a period of a few years (between 4- 6 dependent on the system before you notice a problem) and will require more gas at some point. If you haven't used the system over say the winter, the seals harden and you will notice very poor performance when you use it the first time in summer. There may be some gas in the system, but not enough to have the desired cooling effect. Therefore a top up is all that is needed (and tops up the lube also to slow reoccurance).
In my mind it's cheap but effective quick fix that gets the aircon working in the time it takes to get to halfords and back (plus 5 minutes) versus more expensive, proper fix that may last longer, may provide better results or diagnose major faults.
Just remember about Kwik Fix - 10% better than crap all a/c, is still usually not much cop.
In terms of quantity, I had a small can that I used on three separate cars to top up, each time the performance went from poor to good, and there is still gas left in the can!
Post #6321 2nd Jul 2009 2:41pm
Its def' true that if you don't use the aircon you lose it. My wife's 330D stopped cooling after a year from new cos she never used it. I tried telling her its not just for cooling but also for drying the air in winter, say when you get in and out in damp or wet clothes etc.
She's paying for it now though! Rolling with laughter
In comparison, the RR was ice cold when we were on holiday on the continent, even when it was 36 degrees outside, I had it set at 20 degrees both sides, air con on, and fan at level 1 only. Chilled! But you see, I use mine all the time. Discovery 4 HSE
Post #6322 2nd Jul 2009 3:47pm
jonny142
Well, thanks for the advice chaps.
I dropped it at the local garage this morning, and they re gassed the system and tested etc. Works a treat now. Just in time for the bad weather !!!!
Post #6328 3rd Jul 2009 12:52pm
