![]() | Home > Technical (L322) > Air Con - Not cold |
Generally if you can hear a hissing noise there isn't enough gas in the system for it to work properly (although there may be enough not to have triggered the low pressure switch)
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 ![]() ![]() ![]() |
Disagree. Have used the refill aerosols in the past from Halfords (albeit not on a RR) on recommendation from a professional aircon engineer I know. Bloody excellent. Worked a treat and only cost circa £11. He said that you're wasting your money on the ones with a gauge on though. Probably a good idea to do regularly anyway as it tops up the lube in the gas. Jonny, if you don't already know this, you should run up your aircon at least 10 mins every week to keep the seals in the system and the bearings operating correctly, otherwise you will lose gas through the seals at a far higher rate than normal (there is always some leakage, which is why you need to top it up every few years). It may even say something similar in the handbook. Automotive aircon types will generally suggest that they fill up the system with a UV dye and that you come back to see if there is a leak. I don't think the extra cost is worth it unless the car is relativley new or has recently been regassed then stopped working. |
The cans in Halfords will not evacuate the system first though so you will just be pumping more stuff in, rather than sucking it all out and then refilling with the correct amount. If you have a leak this will not be detected, the professional machines create a strong vacuum and then measure any drop in vacuum signifying a leak before filling.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1668 ![]() ![]() |
The AC cans with the gauge which Halfords sell for £40 can be had from eBay for about £23. |
Dan, while I agree that you have a point about doing the job correctly, my air con man reckons (rightly or wrongly) that you can't over presurise the system with the aerosol cans as they don't operate at high enough pressures and that the system will fill up and then no more will go in beyond the operating pressure of the can. It was only recommended as a quick fix to get it working again, rather than to ensure you had the A/C operating at peak performance, but I can confirm that it works well enough - I did have doubts until then - and had no detrimental effect to the system (well, not in 5 years anyway!). Just an aside, I'm sure there will be an over pressure relief valve to prevent blowing up the system.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
Its def' true that if you don't use the aircon you lose it. My wife's 330D stopped cooling after a year from new cos she never used it. I tried telling her its not just for cooling but also for drying the air in winter, say when you get in and out in damp or wet clothes etc.
jonny142 Member Since: 29 Oct 2008 Location: Sheffield Posts: 28 ![]() ![]() ![]() |
Well, thanks for the advice chaps.
