![]() | Home > In Car Electronics (L322) > Replacing Bluetooth module, to be set up by dealer or not? |
SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 159 ![]() ![]() |
This sounds a little fishy to me. I simply replaced mine and that was that, works properly now.
Same here, got a new one from Wiggs, updated version as well, plug and play and works like a charm. If the car wasn't outfitted with one from the factory (or dealer) before, then it may need setting in the Car Configuration software. MY 2010 5.0 SC Galway green and sand interior!!
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
The dealer's spinning you a line. You have exactly the same car as me and when I enquired about coding mine to allow iPhone address book capability, they "suggested" that any firmward updates on my exisiting BT module might not work, but I'd have to pay anyway!
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 ![]() ![]() ![]() |
It was my local dealer that first said that it would need to be coded and configured to my car although he also told me that the part was not in stock at LR not even for VOR cars. I then contacted another dealer to check availability and price on the same part number who quickly informed me that it was immediately available and for £127 less than my local, but without prompting said i would have to go to a dealer to get it set up for my car. I can never understand how identical parts can have different prices at LR dealers, i have never had this with any other car i have had before!
I can't see a difference between a "new" module and a "used" one from elsewhere, with the exception of the firmware level, so even if you get an old working one, maybe Wiggs could do an exchange deal on that one? Got - 2017 SDV8 Autobiography in Loire Blue
Bodsy Member Since: 10 Mar 2011 Location: Shropshire Posts: 45 ![]() ![]() |
Dealer is talking complete botox!
Are you sure it's faulty? Who diagnosed it. What are the symptoms? |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 ![]() |
opps wrong post |
