Home > Technical (L322) > air conditioning/heater
marbleweazel
United States 2005 Range Rover HSE 4.4 V8 Java Black
05' HSE - when i have the fan on high sounds good but no air coming out of vents. after some messing around the air eventually comes out. Heat is sometimes cool even when its set on the highest setting on hot. Then sometimes it works fine. Is there a motor or damper that controls the airflow? Defrost seems to work good but as soon as i change in to vent mode the fan keeps running good but no air coming out.
Post #94819 27th Nov 2011 11:00pm
marbleweazel
did some more reading could this be a faulty FSR?
Post #94828 28th Nov 2011 3:00am
sounds like it...
Post #94833 28th Nov 2011 8:13am
