![]() | Home > Technical (L322) > air conditioning/heater |
marbleweazel Member Since: 20 Jul 2011 Location: Sacramento, CA Posts: 13 ![]() ![]() ![]() |
05' HSE - when i have the fan on high sounds good but no air coming out of vents. after some messing around the air eventually comes out. Heat is sometimes cool even when its set on the highest setting on hot. Then sometimes it works fine. Is there a motor or damper that controls the airflow? Defrost seems to work good but as soon as i change in to vent mode the fan keeps running good but no air coming out. |
did some more reading could this be a faulty FSR? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
sounds like it... |
