![]() | Home > In Car Electronics (L322) > radio stopped |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
that sounds like a damp issue to me...when i first got my car it kept losing the radio screen,it turned out to be the nav unit was water damaged...replaced with the mk4 dvd unit all good.. V8 facelift Range Rover Autobiography 22" wheels.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
some easy checks:
If you pull out your nav box and remove the two plugs on the rear. Below the nav towards the sub woofer is the TV tuner box (silver box) remove the two plugs (same plugs as the nav box)...
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
nice 1 thanks for all your help i will report back |
