Home > In Car Electronics (L322) > radio stopped
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
radio stopped
any ideas on this my screen comes on but when i push the the button to turn the radio on it does not come on no power light on the button
any help please
Post #93641 21st Nov 2011 9:31pm
daveo
that sounds like a damp issue to me...when i first got my car it kept losing the radio screen,it turned out to be the nav unit was water damaged...replaced with the mk4 dvd unit all good.. V8 facelift Range Rover Autobiography 22" wheels.
Post #93647 21st Nov 2011 10:07pm
some easy checks:
Look at the fuses first
remove left side cover in the boot and check around for damp - should be dry and covered in dust (unless like me you polish in there Whistle )
Let us know what you find Discovery 4 HSE
Post #93657 21st Nov 2011 10:21pm
If you pull out your nav box and remove the two plugs on the rear. Below the nav towards the sub woofer is the TV tuner box (silver box) remove the two plugs (same plugs as the nav box)...
Now plug the nav plugs into the TV tuner box... Switch on the screen and try your radio... This bypasses your nav computer and resets your AV system...
Refit the plugs back into the original places. Refit your nav box and try your radio again...
Good luck Very Happy
Craig Thumbs Up
Post #93663 21st Nov 2011 11:24pm
dannyp15
nice 1 thanks for all your help i will report back
Post #93722 22nd Nov 2011 11:58am
