Home > Technical (L322) > Wonky fuel guage ................ |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 |
A bit more info is required please |
19th Jun 2009 6:42am |
ex bm Member Since: 10 Jun 2009 Location: uk Posts: 6 |
left the car overnight hoping that it would somehow fix itself !!! - but no.
19th Jun 2009 8:05am |
Ivan Member Since: 12 Apr 2009 Location: N. Ireland Posts: 44 |
Mine ('05 S/C) does this too, usually worse after filling up. My MSV tells me "Fuel Sender 2 Circuit , General Electrical Failure, Circuit short to battery or open (intermittent)" When I get time I'll look at the connector on top of the sender unit, until then use the trip and put in lots of petrol!
19th Jun 2009 10:17am |
I have the car booked in for monday to have it checked out but I want to check the connections to the sender unit myself this weekend just incase its a dodgy connection.
19th Jun 2009 10:51am |
If you do a search BBS Spy did a write-up on replacing his fuel pump, this should point you in the right direction. I'll be interested to hear your results,
19th Jun 2009 1:05pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Monitoring this thread as I have a wonky guage too. Mine reads quarter full and then runs out of fuel. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
25th Jun 2009 7:23pm |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 |
It must be a Landrover trait. My SIII used to do this. Of course the fix for that was to just twist the float on the sender to stop it fouling the side of the tank. Sounds electronic on the RR though.
26th Jun 2009 8:32am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
You may find this interesting reading:
2nd Jul 2009 4:10pm |
