Home > Technical (L322) > Wonky fuel guage ................
ex bm
help
filled up yesterday and have driven 100 miles since - but today fuel gauge dropped suddenly to zero and range is now reading as zero too !!! - but plenty of fuel left in the tank.
is this a common problem or am I just unlucky - will the standard " disconnect battery for 10 mins" trick solve ??
any other suggestions appreciated???
thanks.
Post #6203 18th Jun 2009 10:29pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
A bit more info is required please
Post #6205 19th Jun 2009 6:42am
ex bm
left the car overnight hoping that it would somehow fix itself !!! - but no.
fuel gauge still reading empty and range is zero.
is there a fuse that controls fuel sender that i check ???
sorry forgot to say it is an 06 supercharged.
thanks,
Post #6207 19th Jun 2009 8:05am
Ivan
Ireland 2005 Range Rover Vogue SE Supercharged Zermatt Silver
Mine ('05 S/C) does this too, usually worse after filling up. My MSV tells me "Fuel Sender 2 Circuit , General Electrical Failure, Circuit short to battery or open (intermittent)" When I get time I'll look at the connector on top of the sender unit, until then use the trip and put in lots of petrol!
Ivan FF RR S/C (Gone)
TVR Chimaera 500(Gone)
TR7 V8
Post #6208 19th Jun 2009 10:17am
ex bm
I have the car booked in for monday to have it checked out but I want to check the connections to the sender unit myself this weekend just incase its a dodgy connection.
i presume the sender unit is at the top of the tank and will be accessible from within the boot floor - is this correct ??? - any guidance on how to access would be great.
i know the car has saddle tanks, so does this mean it has a sender in each tank, or just one and a pump to keep them balanced ??
thanks,
Post #6210 19th Jun 2009 10:51am
Ivan
If you do a search BBS Spy did a write-up on replacing his fuel pump, this should point you in the right direction. I'll be interested to hear your results,
TR7 V8
Post #6212 19th Jun 2009 1:05pm
Andy
Monitoring this thread as I have a wonky guage too. Mine reads quarter full and then runs out of fuel. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #6266 25th Jun 2009 7:23pm
Larry
England 2006 Range Rover SE Td6 Java Black
It must be a Landrover trait. My SIII used to do this. Smile Of course the fix for that was to just twist the float on the sender to stop it fouling the side of the tank. Sounds electronic on the RR though.
Has anyone had a look at the mechanical side of things to rule it out (ie. float getting fouled etc)?
Post #6272 26th Jun 2009 8:32am
You may find this interesting reading:
http://www.fullfatrr.com/forum/topic792.html Discovery 4 HSE
Post #6325 2nd Jul 2009 4:10pm
