Home > Technical (L322) > front grill |
Think the badge is just stuck on with 3m double sided tape, just get a 0.6mm guitar string or something similar and kind of do a sawing motion behind the badge .................and it should come off....... |
11th Jun 2009 4:23pm |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 742 |
Took my grill off to swap the green and gold Land Rover badges with the black/silver ones, it's 3 screws and takes about 2 mins, if you look at the instructions for changing the headlight bulbs it shows you how to remove the front grill. To get the badge off I heated up the old one with the wife's hairdrier and pushed it out from behind (there is a small hole behind the badge) when the 3m tape / glue started to give a little. To fully remove the grill you need to slide out the temp gauge that sits inside the grill. |
11th Jun 2009 11:22pm |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 |
As Jez said |
12th Jun 2009 6:25am |
PLUMBERMAN Member Since: 15 May 2009 Location: widnes, cheshire Posts: 12 |
thanks boys , will pinch mrs h hairdryer, as anyone else sprayed their gril to match bodywork colour. if so did you use a clear Lacquer over spray to protect from stone chips? |
12th Jun 2009 3:05pm |
Yeah that's what i got done but i also got the outside rim of the grill painted black .................
12th Jun 2009 3:20pm |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2040 |
Mick
12th Jun 2009 3:25pm |
Thats the standard s/c 10 spokes |
12th Jun 2009 3:39pm |
pyramid1235 Member Since: 25 Mar 2009 Location: Glossop Posts: 20 |
That grill looks really good painted round the edge |
15th Jun 2009 6:22pm |
Cheers, glad somebody likes it .......... |
15th Jun 2009 7:02pm |
