Home > Technical (L322) > front grill
PLUMBERMAN
United Kingdom 2004 Range Rover Vogue Td6 Java Black
front grill
not realy technical ,but has anyone removed the front badge on the grill as i want to remove mine to colour code from grey to black ,have looked in manual but can;t find anything .thought i would ask before i Censored it up
Post #6137 11th Jun 2009 3:53pm
Think the badge is just stuck on with 3m double sided tape, just get a 0.6mm guitar string or something similar and kind of do a sawing motion behind the badge .................and it should come off.......
Post #6138 11th Jun 2009 4:23pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Took my grill off to swap the green and gold Land Rover badges with the black/silver ones, it's 3 screws and takes about 2 mins, if you look at the instructions for changing the headlight bulbs it shows you how to remove the front grill. To get the badge off I heated up the old one with the wife's hairdrier Embarassed and pushed it out from behind (there is a small hole behind the badge) when the 3m tape / glue started to give a little. To fully remove the grill you need to slide out the temp gauge that sits inside the grill.
Post #6139 11th Jun 2009 11:22pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
As Jez said Thumbs Up
Post #6140 12th Jun 2009 6:25am
PLUMBERMAN
thanks boys , will pinch mrs h hairdryer, as anyone else sprayed their gril to match bodywork colour. if so did you use a clear Lacquer over spray to protect from stone chips?
Post #6143 12th Jun 2009 3:05pm
Yeah that's what i got done but i also got the outside rim of the grill painted black .................
Post #6144 12th Jun 2009 3:20pm
nbunney
Mick
What wheels you got on in the pic above?
Post #6145 12th Jun 2009 3:25pm
Thats the standard s/c 10 spokes
Post #6146 12th Jun 2009 3:39pm
pyramid1235
United Kingdom 2006 Range Rover Vogue Td6 Java Black
That grill looks really good painted round the edge Thumbs Up
Post #6178 15th Jun 2009 6:22pm
Cheers, glad somebody likes it .......... Thumbs Up
Post #6179 15th Jun 2009 7:02pm
