Home > Technical (L322) > Clattering Noise When Turning ( Coming from NSF )
Mapmuppet
Folks,
Annoying clattering noise coming from the NSF when turning to the right at moderate speed, just changed the drive shaft but noise is still there ?
Any assistance would be greatfully recieved......
Can't use this as an excuse to purchase a new FFRR 2010 model 2005 Audi A8 W12
1978 Mercedes 450 SEL 6.9
1986 Mercedes 420 SL 4.2
Post #6080 9th Jun 2009 9:44am
Sounds like a bearing type joint breaking up maybe? I'm not sure what they call it these days, used to be a CV joint, or known as a Wheel bearing in normal cars I think.
Have you done a visual check to see there's nothing out of place in that area? Discovery 4 HSE
Post #6093 9th Jun 2009 6:29pm
dantheman
Sounds like it could be a wheel bearing to me - shouldn't be a CV joint as incorporated into driveshaft (which you've already changed.
With the vehicle sat on flat level ground, get a good hold of the suspected wheel (about 10 & 2 O'clock position) and rock (push/pull) with considerable effort - probably worth repeating on all wheelstations and comparing... You should feel the wheel station rocking with excess freeplay if the bearing is on it's way out. Also don't be afraid of getting a torch and having a good look around the hub assembly at the back of the wheelstation - you may see something there.
Hope this helps some... Thumbs Up
Post #6100 9th Jun 2009 11:07pm
Mapmuppet
Thanks Guys appreciated. I'll keep you posted.... 2005 Audi A8 W12
Post #6108 10th Jun 2009 9:19am
Mapmuppet
Well, one week on and 2 days in the local Land Rover dealer and still the same problem. The drive shaft has been changed and apparently there was a recall/mod on the early LR322 models which involves modifying the front diffs. Not sure if anyone is aware of this. This was thought to be the cause of the problem, but no Sad
Think its a sign to order a new 2010 FFRR ! 2005 Audi A8 W12
Post #6188 17th Jun 2009 7:12pm
dantheman
Yes, was a well documented problem with the BMW transmission - front diffs/final drives req'd modifying...
Why did the garage release the vehicle with the fault still present???
Post #6191 18th Jun 2009 1:01am
jonny142
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi there,
I had a similar problem, turned out that i needed a new steering rack. Local steeler charged me £1100.
Cheaper on Ebay 4.4 V8 Vogue Adriatic - Cream leather
Post #6196 18th Jun 2009 4:15pm
Mapmuppet
Thanks Jonny, dealership still recon its the 'clips' at either end of the drive shaft ???
Has anyone got any diagrams of a driveshaft to show these ?
Thanks again 2005 Audi A8 W12
Post #6248 23rd Jun 2009 3:01pm
