Home > General > LPG
m90got
United Kingdom 2003 Range Rover HSE Td6 Alveston Red
LPG
Went for a test ride in a 2004 4.4 v8 LPG conversion last nite and the differance between it been on petrol and lpg was very noticable seller said this is common, could any of you kind people out there let me know if this is the case or just a bit of sales man ship
Cheers Paul.
Post #89092 27th Oct 2011 10:15am
Dolphinboy
I can't tell hardly any difference on mine ('04 4.4 V8 LPG). When I bought it the seller made the switch between the 2 types as we were accelerating and there was hardly any difference.
I am not any type of expert on LPG but I would have someone knowledgeable have a good look at the settings. May need a service (they should be done yearly - check when it as last done (and ask for receipts!).
Post #89093 27th Oct 2011 10:28am
m90got
Cheers how much does the service cost approx
Post #89094 27th Oct 2011 10:39am
mzplcg
OK, be careful. This sounds wrong. And the seller is being economical with the truth.
It USED to be the case that there was less power available on LPG due to its lower calorific value and this was on pre-electronic systems. On newer systems the fuelling is much more accurate to prevent stuff like lean-mix backfires, valve seat burn etc.
So, what happens with the new electronic injection LPG systems is that the power remains almost identical and the MPG drops accordingly. Expect 20% less miles per gallon on gas when compared to petrol.
If the car is noticeably down on power when running on LPG it could be any number of things which is causing it. These range from having an inappropriate kit fitted (walk away quickly) to the LPG system just needing a service. (unlikely).
If I were to guess I would suspect something like a failed diaphragm in the vapouriser, maybe the filter is blocked with heavy ends, perhaps even a failed injector. Whatever it is though it will not be 20 quid to fix it. Any information you can get about the make of the system fitted will help but the mainstream ones will cost IRO 100 quid fitted for a diaphragm, injectors are upwards of 40 quid each depending on make, and you need to factor in technician time to set it all up.
Look to negotiate a serious discount (at least a grand) or have the seller fix the problem before you buy it.
Dom
Post #89095 27th Oct 2011 11:11am
m90got
Cheers Dom that was very helpfull just found another one on ebay eBay Item No. 260878981103
think this will be the one
http://www.ebay.co.uk/itm/06-09-SUPERCHARG...3cbd9957ef
Post #89097 27th Oct 2011 11:21am
Dolphinboy
Looks like a stunning car. Price is at the top end I would think. But it is in excellent nick by the looks of it. You should look at having it LPG'd for around £1.5-£2k and factor this into your offer price.
FYI, I get around 250 miles for £50 of LPG. (20p per mile, same as my diesel.) LPG kit Servicing is only £150 - there is lots of advice here to see which system to use. Mzplcg is a font of knowledge on this as was Dan_uk-1984.
go for it!
Post #89101 27th Oct 2011 11:59am
Hmm, everything supercharged except just one thing - it doesn't have a supercharger!
I was intrigued when it said FULL supercharged conversion, but I guess that didn't include the bits under the bonnet! Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #89121 27th Oct 2011 1:21pm
My system has no differenc in power when on LPG or petrol. Had it serviced a few weeks back and was £80. Changed the filters and retuned the ECU plus some other bits. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #89132 27th Oct 2011 2:25pm
m90got
now sold
missed out on another one just not going to happen must be me a bit to picky,
none for sale in lincolnshire area well none that havent been driven by a space traveler lol
Post #89215 27th Oct 2011 7:15pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
The advert could have been doing with a few more pictures Rolling with laughter Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #89230 27th Oct 2011 9:14pm
M90got
Might know where there's one coming up in the next few weeks Wink Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #89233 27th Oct 2011 9:28pm
fisha
You can tell a difference on my 4.4 V8 between the petrol and lpg, but I would only really say at moderate load.
Switch over onto lpg when driving, you cant tell ... its totally smooth, you simply wouldn't know.
Kickdown acceleration, cant tell either, the car boots its either way on petrol or lpg - sounds great.
Moderate acceleration, yeah, you can tell slightly. On petrol, there is just a little bit more grunt to the engine, both in terms of pull, and sound. You're going to laugh, but on petrol the engine is a bit more "grrrrr" sounding.
On lpg, I liken it to taking a bit of sandpaper to softening off the hard edges of the engine. Still the same shape, just a wee bit softer all round.
thing is though, on lpg, you're more likely to press the accelerator that wee bit harder. Which more than makes up for it. V8 or else ...
Post #89250 28th Oct 2011 7:54am
m90got
going shopping for a ffrr tom must find one or i might have to stick with the shogun sport like thats going to happen lol well fingers x
rob if you would keep me informed cheers
Post #89339 28th Oct 2011 7:49pm
