Home > Technical (L322) > Westfalia or Towtrust, detactchable towbar, help
chesh
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi, my RR was registered new in March 2006 but the build date was october 2005 and its a 3.0 td6, I am struggling to get any sence out of the towbar companys as to which Westfalia to purchase , as there is two different types for this model, some are saying its to do with the exhaust brackets and some are saying its the engine.
Any ideas .
I have had quite a few quotes and a lot of the towbar companys are trying to sell me the towtrust detachable, which is obviously cheaper than the westfalia.
Any one had one of these fittedjavascript:emoticon('Sad')
Post #86714 11th Oct 2011 5:06pm
JustinP
Post a photo of showing how your rear exhaust box fixes to the body, and we can tell you whether you need the old or the new style.
Post #86716 11th Oct 2011 5:19pm
Do you want detachable or not really bothered as all in my Towtrust and landrover bits came to about £250 and i installed it myself Smile
Im guessing like me you have a pre-facelift model. I had to bend the bracket a little for the exhaust clamps but its been fine since fitting and the exhaust has had a few boulder bash's.....
Post #86772 11th Oct 2011 7:08pm
chesh
Hi thanks, I will take a photo tomorrow and post it. Cheers
Post #86793 11th Oct 2011 8:26pm
chesh
Hi I hope these photos are ok and you can tell which Vestfalia bar I need. Smile Rolling Eyes
Great I done it with the help of scarey, thanks again. Surprised
Post #87185 13th Oct 2011 10:43am
try this chris,
click on gallery underneath the fullfatrr.com logo,
on the black banner click on upload photos
click on browse and select your pic from your pc/laptop
click continue 4 times
click on your pic and it will increase in size and have the file info
click on and copy the bb code full size and paste onto your post ... - .- -.
Post #87187 13th Oct 2011 10:50am
Looks like mine but mine hangs down an extra inch at the minute as i need to sort it properly but it hasn't affected anything really Smile
Post #87188 13th Oct 2011 11:22am
JustinP
From what I can see in the photo's it also looks the same as mine which is the later style. The earlier style had welded exhaust mounts part way along the long section, where as the later style like yours has a separate exhaust bracket each side which is bolted on.
The photo below shows the armature for the earlier style and it clearly shows the welded exhaust brackets
if your exhaust brackets are looking rusty, a pair of replacement brackets are only about a £10 from the main dealer, i replaced mine to save fighting with stubborn nuts.
Post #87257 13th Oct 2011 6:02pm
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
I've got a Westfella/ Thule detachable tow bar on mIne and it's great
Post #87268 13th Oct 2011 7:18pm
chesh
Hi my RR is the face lift model,,touch screen, voice activation, shaped front headlights, etc, do you know the part number for the later westfalia bar.
Wink
Post #87276 13th Oct 2011 7:52pm
