Home > General > Do i need to remove the mud flaps when changing side vents?
starman
Sweden 2005 Range Rover Vogue 4.4 V8 Giverny Green
I´m going to change the two wing side vents for the three wing.
I´m not at all a DIY guy, but i have seen on the webb how to do it.
Doesn´t look to hard.
My 05 has the mud flaps, do i need to remove them when changing the vents?
Post #86455 10th Oct 2011 1:10pm
i think you might have to unless when you click out the bottom panel theres enough flexibility to move the panel out the way.. ... - .- -.
Post #86457 10th Oct 2011 1:16pm
http://www.fullfatrr.com/forum/topic1069.h...side+vents
Post #86458 10th Oct 2011 1:18pm
You can just about manage it if you have a long extension for your socket too reach the top bolts
Post #86459 10th Oct 2011 1:18pm
I did mine a few weeks ago.. I have mud flaps and side steps. It was easy, there is enough room. I was shocked at how much earth etc was stuck behind the panel, so I was glad to give it a good clean out as well. Previously..
Post #86535 10th Oct 2011 6:20pm
