Home > Technical (L322) > Drivers door lock actuator
saxrom
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
My drivers door has stopped locking with the remote but still locks with the key so i take it the actuator has given up the ghost any ideas where to get one and how hard a job it is to change Big Cry
Post #5508 12th May 2009 11:38am
No need for the BOLD TYPE, we can hear you!
Are the batteries in the keyfob flat? That would be my first port of call.
Are the other doors locking but not the drivers door? (If so then you can probably ignore the above) This might then suggest the actuator is at fault.
Always start with the most basic and cheap potential fix and work your way up. Discovery 4 HSE
Post #5511 12th May 2009 1:11pm
