Home > General > Replacement console parts
Post #83591 24th Sep 2011 6:37am
Does nail varnish remover work to get it off at all or how about a jet wash Very Happy
Post #83593 24th Sep 2011 6:56am
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Will, I think it may be the same stuff that was on the centre dash of a certain Italian 5-cylinder thing - and as I recall people tried every chemical known to man in an unsuccessful attempt to remove that! Hence asking what was used here!
Post #83600 24th Sep 2011 8:08am
Ahh i recall Smile
I wonder how a quick splash of nitromorse would go... works well on 4 pot brembos when baked in the oven as well Very Happy
Post #83604 24th Sep 2011 8:33am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I used metal polish to get the rubber coating off some internal panels. Leave it on for a few minutes to soften the coating then rub, rub and rub again with a soft cloth. Eventually it will come off. Don't use anything abrasive or you will scratch the surface underneath (not too much of a problem if you are going to repaint I guess) No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #83646 24th Sep 2011 6:41pm
daveo
i tried a number of things from turps and white spirit, i think it was the light coat of thinners that made it go soft and then a bit of elbow grease and it all came off..spray short light coats to build up a texture finish, to much to quick will give you a heavy finish. V8 facelift Range Rover Autobiography 22" wheels.
Post #83653 24th Sep 2011 7:37pm
