![]() | Home > General > Replacement console parts |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Does nail varnish remover work to get it off at all or how about a jet wash |
Ahh i recall |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
I used metal polish to get the rubber coating off some internal panels. Leave it on for a few minutes to soften the coating then rub, rub and rub again with a soft cloth. Eventually it will come off. Don't use anything abrasive or you will scratch the surface underneath (not too much of a problem if you are going to repaint I guess) No longer FF owner but still interested. Present car Jaguar XE
i tried a number of things from turps and white spirit, i think it was the light coat of thinners that made it go soft and then a bit of elbow grease and it all came off..spray short light coats to build up a texture finish, to much to quick will give you a heavy finish. V8 facelift Range Rover Autobiography 22" wheels.
