![]() | Home > Technical (L322) > OBC message but no apparent fault? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I'm getting a message on the OBC - "numplate light check" but it's working OK.
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
not changed to leds have you |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
every time i plug in my trailer I get "Check trailer light". All works so not bothered. Discovery 4 HSE
Sometimes it only needs to have a flicker and it will throw a message. I get it with a side light. ![]() |
Are you using the accessory socket as well? This caries the reversing light pins, it may be complaning about lack of that if you're using single electrics. Dan ![]() |
None of the above. Just does it when I switch on and off. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
