Home > Technical (L322) > OBC message but no apparent fault?
Andy
I'm getting a message on the OBC - "numplate light check" but it's working OK.
Anyone had this or similar? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #5440 7th May 2009 10:58am
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
not changed to leds have you Question
Post #5441 7th May 2009 11:02am
every time i plug in my trailer I get "Check trailer light". All works so not bothered. Discovery 4 HSE
Post #5442 7th May 2009 1:54pm
dan_uk_1984
Re: OBC message but no apparent fault?
Sometimes it only needs to have a flicker and it will throw a message. I get it with a side light.
Post #5443 7th May 2009 2:19pm
dan_uk_1984
Are you using the accessory socket as well? This caries the reversing light pins, it may be complaning about lack of that if you're using single electrics.
Dan
Post #5444 7th May 2009 2:20pm
Andy
None of the above. Just does it when I switch on and off. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #5448 7th May 2009 8:09pm
