![]() | Home > In Car Electronics (L322) > No Entertainment System |
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
might be a fuse?, or look in the rear nearside compartment and have a look out for a silver box with a blue and white white connectors in to it, the pins inside the connectors might be corroded i hope this is of any use. |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
thanks for reply. i locked car and went away for a brew. went back out unlocked car and hey presto it all fired back up into action. maybe needed a moment or two to sort itself out!!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
glad its all fine again stu, but keep an eye on the battery cos if its fairly old it might need replacing.. ... - .- -.
@ Scarey.. what makes you lean towards a battery issue... curious??
just a thought that a 'worn' battery might not have had the power to get every thing going when you re-connected it but after having it connected for a while it did.. ... - .- -.
ok, good point i suppose and taken on board thanks.. |
I would imagine the ecu stayed asleep when you reconnected your battery... In locking your car and leaving for a couple of mins then opening and putting the ignition on, normal service was resumed!
thanks for that Craig.. |
