Home > In Car Electronics (L322) > No Entertainment System
stu
hi everyone,
i had the battery disconnected this afternoon so i didn't pop anything when i was doing my towing electrics.
i connected the negative terminal again, everything seemed to work, started the car and did the steering wheel etc, but no radio, sat nav etc. the screen is blank and i can't get anything from it.
is there something i need to do to bring it back to life? i have never had the battery disconnected before so have'nt encountered this problem before. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #82019 17th Sep 2011 4:52pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
might be a fuse?, or look in the rear nearside compartment and have a look out for a silver box with a blue and white white connectors in to it, the pins inside the connectors might be corroded i hope this is of any use.
Post #82027 17th Sep 2011 5:23pm
stu
thanks for reply. i locked car and went away for a brew. went back out unlocked car and hey presto it all fired back up into action. maybe needed a moment or two to sort itself out!!
all is well in my life again.. Laughing Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #82041 17th Sep 2011 6:46pm
glad its all fine again stu, but keep an eye on the battery cos if its fairly old it might need replacing.. ... - .- -.
Post #82067 17th Sep 2011 8:58pm
stu
@ Scarey.. what makes you lean towards a battery issue... curious??
evrything else was fine as soon as i reconnected the negative lead, just the head unit not wanting to fire up.
i was maybe thinking about a new battery later in the year especially if it gets cold again like the last couple of winters. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #82076 17th Sep 2011 9:16pm
just a thought that a 'worn' battery might not have had the power to get every thing going when you re-connected it but after having it connected for a while it did.. ... - .- -.
Post #82083 17th Sep 2011 9:20pm
stu
ok, good point i suppose and taken on board thanks.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #82088 17th Sep 2011 9:26pm
I would imagine the ecu stayed asleep when you reconnected your battery... In locking your car and leaving for a couple of mins then opening and putting the ignition on, normal service was resumed!
If it starts happening on a regular basis i would first change the battery if its not been changed for a while...
Craig Thumbs Up
Post #82109 17th Sep 2011 11:10pm
stu
thanks for that Craig.. Thumbs Up
always good to get peoples thoughts and knowledge Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #82132 18th Sep 2011 7:19am
