![]() | Home > In Car Electronics (L322) > Sat nav, cd player, reverse cam, screen not working |
HUGI Member Since: 23 Oct 2010 Location: Jona-Rapperswil Posts: 244 ![]() ![]() ![]() |
have sometimes the same problem: the whole system is stuck on the boot screen.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Also check the phone module, if that not connected it shuts down. |
rory_mcw Member Since: 08 Apr 2009 Location: Angus - Scotland Posts: 113 ![]() |
I have left it sitting last night, and disconnected the battery for an hour.
Oh I forgot to ask: does this always happen?
how do i check them? i might have to take my head unit out.......
well I would start with the connections which are easy to check. (in the boot)
checked connections,
If the phone module is disconnected or :censored:ed then it gives the same symptoms.
The MOST fibre optics are connected in a loop. So if you disconnect any of the MOST connectors, the system stops. In my 2006 MY S/C the Bluetooth module was f |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
its a feature not a bug as they say does it very occasionlly on mine did it this morning switched off engine came back 5 mins later and works again, i think its something to do with damp, always happens when it has been a bad night, low pressure and what not, i learn to live with it as i know it will come back
i have a red light going into my bluetooth module.......... but nothing coming out of it.................. how do i loop the circuit? thanks rory |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
you need M.O.S.T connectors...if you can find them rory, they seem to be pretty rare.. .. |
