![]() | Home > General > Juddering / grinding sensation steering left while driving |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Sounds similar to a problem I had, front left drive shaft broken.
choson1 Member Since: 12 Aug 2011 Location: SoCal Posts: 6 ![]() ![]() ![]() |
how often did you feel the grinding? since i posted this, i've only experienced it one more time. my car is a 2006 vogue. thanks. |
S1NGH Member Since: 08 Apr 2009 Location: All over Posts: 40 ![]() ![]() |
Sounds like DSC/ traction control kicking in - can be caused by uneven tread or tyre pressure differences between different wheels, actually quite a few possible causes.
i believe you are correct. one of my front tyres is low on pressure. thanks for your help. |
i've decided to get with the program and start spelling it "tyre" instead of "tire"
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
better get that steering wheel on the correct side ! ![]() ![]() |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
A few things - what you call 'gas' is called petroleum spirit over here, and we buy it in the chemists in measures of gills and they will also charge your accumulator for you if required. The car radio or ICE is called the wireless and only picks up the Home Service and we always navigate using the AA book of the road printed in 1964. ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35618 ![]() ![]() |
class.. ![]() Y. O. L. O. . |
say what? speak english please! ![]() |
