Home > Technical (L322) > P040D - DPF Temp sensor failure .... HELP!!!!
Crusty21
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
D3Jon many thanks, that's good to know.
I reckon I'll just leave it alone now and keep an eye on it.
If the failed sensor doesn't affect DPF regen, mpg or any other "processes" then would you have any idea what its function is? ..... beyond simply a temp sensor?
Thank you to everyone here on this thread, your help is most appreciated Thumbs Up
Cheers
Neil 2011 TDV8 4.4 Vogue SE
Post #716631 23rd Apr 2025 10:20am
cass
"If the failed sensor doesn't affect DPF regen, mpg or any other "processes" then would you have any idea what its function is? "
To line the pockets of impoverished main dealers? or possibly to keep the "technicians" entertained as they must get bored having nothing to do all day due to the magnificent reliability of the brand?
Post #716650 23rd Apr 2025 4:02pm
pcourtney
its common
https://www.fullfatrr.com/forum/topic38739.html?highlight=p040d
Post #716669 23rd Apr 2025 8:43pm
D3Jon
That's a fair question, and yes it must perform some function, manufacturers don't add parts just for fun! Very Happy
I'm not exactly sure what the ECU does with that sensor's measured temperature values, though. I just know the TDV8 engine seem unaffected by that error code and many people just live with it, due to the limited access issues (manifold heat shield) on the L322 installation and the risk of snapping the sensor off. Certainly, it's not a significant enough error to bring up the Engine Management warning light on the dash.
I do seem to remember from another discussion on this topic, that the ECU calculates an interpreted value if that sensor isn't providing an 'expected' value, or is giving a short to earth fault. But can't say that with total certainty, as I can't find that information any more.
As others have said, that fault code should not affect DPF regen's occurring.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #716758 25th Apr 2025 9:16am
Crusty21
Many thanks Jon Thumbs Up
I had been told if the fault code was present then a regen would be impossible ..... and the consequences of that etc etc. Rolling Eyes
I took the vehicle out yesterday and forced a regen .... it worked perfectly.
In conclusion, the wisdom of this group is far superior to that of many Indy garages
Cheers All, really appreciate the help.
My wallet is grateful too Very Happy Very Happy 2011 TDV8 4.4 Vogue SE
Post #716778 25th Apr 2025 2:28pm
