Home > Maintenance & Mods (L322) > Stripped Thread on Brembo Front Calliper
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Looking for advice whilst trying to bleed front brakes after some work I have stripped threads on Front Brembo caliper any suggestions on how to fix this
Thanks
Post #715542 4th Apr 2025 2:55pm
Mikey
Bleed nipple threads or carrier bolts?
Post #715546 4th Apr 2025 3:32pm
Pat
Bleed nipple thread
Post #715548 4th Apr 2025 3:40pm
Mikey
OK, so. Bear with me Laughing
Nipple Therapy
It's an actual repair kit, with a drill bit, appropriate sized tap and new bleed nipples to drill out and reseal Thumbs Up
Post #715551 4th Apr 2025 4:28pm
Gremlin500
United Kingdom 2017 Range Rover Vogue TDV6 Corris Grey
@Mikey:
Not seen this before, care to post your source? Bow down
@Pat:
To stop this happening again and next time trashing your calipers:
Take each new bleed nipple, and very carefully wrap each with 3 to 4 turns of PTFE tape, being very careful not to let any stray tape get anywhere near the inner part of the nipple (where the brake fluid is)
This will provide a dielectric barrier between the two dissimilar metals, and prevent the galvanic corrosion from welding the steel nipples to the aluminium caliper body.
I have done this for years, and it just works. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #715568 5th Apr 2025 12:25am
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Brake nipple repair search on eBay gives a variety of results including the therapy thing pictured, at 85 quid! Nielsen do a similar looking kit for 24 quid and big red (good supplier) do a kit with helicoils and all the tooling for 15 quid.
Chris
Post #715607 5th Apr 2025 4:14pm
