![]() | Home > Maintenance & Mods (L322) > Ball Joint screw size |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
If you are asking of the ball joint thread... Type Ball Joint. External Thread Size M14 x 1,5. LAND ROVER RBK000010 . I you want the tread of the retaining torx screws they are M10 x 20mm. If you are changing the retaining torx screws do yourself a big favour and get normal hex head bolts, it will make your life so much easier especially if the new ball joint is a very tight fit.
rik__ Member Since: 12 Mar 2024 Location: UK Posts: 27 ![]() ![]() ![]() |
sounds like a good idea, just got to get them out first |
I have done this now on 4 cars and even in Australia with zero rust they have all been a pain to get out hence replacing with proper bolts to press the new in. On the earlier pre facelift cars getting the balljoints out and in proved a real task as they were so tight, on two facelift cars they came out and went in with ease, not sure why a difference. 2007 TDV8 VSE
