Home > Maintenance & Mods (L322) > Ball Joint screw size
rik__
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Hi Guys just trying to do the arms on my 2004 l322
im not sure what size these screws are ive seen some people saying they are an M10, my m10 bit is way to big to fit. could they have been changed before? or anyone know whats the typical size
thanks
Post #715112 29th Mar 2025 3:06pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
If you are asking of the ball joint thread... Type Ball Joint. External Thread Size M14 x 1,5. LAND ROVER RBK000010 . I you want the tread of the retaining torx screws they are M10 x 20mm. If you are changing the retaining torx screws do yourself a big favour and get normal hex head bolts, it will make your life so much easier especially if the new ball joint is a very tight fit.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #715114 29th Mar 2025 3:43pm
rik__
sounds like a good idea, just got to get them out first
Post #715192 30th Mar 2025 3:11pm
wayneg
I have done this now on 4 cars and even in Australia with zero rust they have all been a pain to get out hence replacing with proper bolts to press the new in. On the earlier pre facelift cars getting the balljoints out and in proved a real task as they were so tight, on two facelift cars they came out and went in with ease, not sure why a difference. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #715196 30th Mar 2025 3:25pm
