![]() | Home > Maintenance & Mods (L322) > Running Boards |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 712 ![]() ![]() ![]() |
If it's just a running board like you say, just buy the whole unit. But if it's deployable sidesteps that you have fitted, then I'm afraid you are right out of luck as they are like hens teeth and should you source a bracket it's going to be very expensive. |
Proftinkerpot Member Since: 22 Dec 2022 Location: County Antrim Posts: 193 ![]() ![]() ![]() |
Stuart on here has reproduced deployable step brackets. They are around £90 each1 from memory. |
Stuart on here has reproduced deployable step brackets. They are around £90 each1 from memory. His name on here is Oggy. |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 195 ![]() ![]() ![]() |
My running board brackets were in a terrible state when I bought the RR, near rusted through, I made 4 new ones from a length of 4mm u-profile painted it with Hammerite and every other black paint I could find and they are fine 4 years later. If you don't have the facilities to do it yourself get a local metal basher to fabricate them.
