![]() | Home > Technical (L322) > L322 2011 TDV8 - Parking Sensors |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 ![]() ![]() ![]() |
If the button does not flash at all then IME it's the PAM ( Parking assist module). Unfortunately they are prone to failure due to water ingress
neilrjones Member Since: 03 Nov 2015 Location: Devizes - Wilts Posts: 13 ![]() ![]() ![]() |
Great thanks - and this would be the issue even with the camera working? I'd thought, probably incorrectly, that this would be dead too if the PAM was knackered...
The reverse camera is not connected to the PAM (which is either a good design or accident by JLR) 2012 TDV8 Vogue (L322) |
Cracking - thank you! |
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 ![]() ![]() ![]() |
I have a similar problem but the LED is always on (with ignition) but the cameras seem to be fine although the delay annoys me.
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 84 ![]() ![]() ![]() |
Sorry to hijack but having just acquired myself a 2012 TDV8 Westminster and working through the inevitable teething troubles, as this isn't one of them could someone tell me where the PAM is located so that if possible I can take some preventative measures to protect it?
It's located behind the flap at the left rear of the luggage compartment. Lower rear with three plugs inserted from above.
lpdotcom Member Since: 03 Oct 2024 Location: Victoria Posts: 1 ![]() ![]() ![]() |
I've got a 2010 facelift model and parking sensors weren't working. Ordered and fitted a new PAM (previous one had most definitely failed due to water ingress with much green corrosion). I'm now getting the warning tone and flashing parking sensor light that is telling me that the system is inactive. Have plugged the OBD scanner in to look for codes and get:
