Home > Technical (L322) > L322 2011 TDV8 - Parking Sensors |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
If the button does not flash at all then IME it's the PAM ( Parking assist module). Unfortunately they are prone to failure due to water ingress
16th Nov 2023 2:03pm |
neilrjones Member Since: 03 Nov 2015 Location: Devizes - Wilts Posts: 12 |
Great thanks - and this would be the issue even with the camera working? I'd thought, probably incorrectly, that this would be dead too if the PAM was knackered...
16th Nov 2023 2:57pm |
The reverse camera is not connected to the PAM (which is either a good design or accident by JLR) 2012 TDV8 Vogue (L322) |
16th Nov 2023 3:26pm |
Cracking - thank you! |
16th Nov 2023 9:26pm |
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 57 |
I have a similar problem but the LED is always on (with ignition) but the cameras seem to be fine although the delay annoys me.
16th Dec 2023 1:18am |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 72 |
Sorry to hijack but having just acquired myself a 2012 TDV8 Westminster and working through the inevitable teething troubles, as this isn't one of them could someone tell me where the PAM is located so that if possible I can take some preventative measures to protect it?
16th Dec 2023 4:10pm |
It's located behind the flap at the left rear of the luggage compartment. Lower rear with three plugs inserted from above.
16th Dec 2023 6:04pm |
