![]() | Home > Technical (L322) > EAS Fault - 0x7A Reservoir Pressure rises when lifting |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 965 ![]() ![]() |
Have you drilled a hole in the filter on the air pump yet ? If not do it. |
RogueRanger Member Since: 03 Jan 2024 Location: Kent Posts: 116 ![]() ![]() ![]() |
That style of code seems to come and go all the time. I don’t think they are actually fault codes and that may be why you’re not finding anything on Google.
jamiej Member Since: 01 Dec 2023 Location: Surrey Posts: 54 ![]() ![]() ![]() |
Thank you.
Yes you can just remove the cone filter from the pump |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1361 ![]() ![]() |
Yeah, if you resort to drilling a hole in it, just remove it and throw it away, it basically the same thing 👍😎 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8459 ![]() ![]() ![]() |
IIRC this is a "hard" fault, it will not clear when you have rectified the problem. It will need a diagnostic tool to erase... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
