![]() | Home > Maintenance & Mods (L405) > L405 DRL |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35548 ![]() ![]() |
i want the same as you..twas available on the 2015/2016 models when landrover thought it was going to be law but this did not happen so they reverted to front drls only from then..
chicb Member Since: 27 Nov 2019 Location: Dundee Posts: 94 ![]() ![]() ![]() |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
I cheated when I had my first 405 and simply put a jumper fuse holder wire thingy with a blocking diode in it between the DRL fuse and the rear light fuse/s.
thats clever Craig...i wish i know how to do that..
Can you solder Stan? |
i can |
I don't think Patrick ever did this? |
Could there be a CCF for later cars Stan? Ive seen some working on late cars... I have a 20/21 in now with rear DRL working |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2604 ![]() ![]() |
I don't think my MY21's front DRLs are bright enough for open road use in the Australian sunlight so I'm switching on the headlights when I remember. I had my L322's headlights set as DRLs.
Try changing the CCF to Scandinavian Graeme as they have to have 55w front lamps on as standard 24hrs... IE brighter than DRL's |
Idiots guide would be good. I'm willing to give it a go ![]() |
Thanks Craig, that's what I had my L322 set to, but I suspect that I need a G4 IIDtool to do much with my MY21. I was suprised that my G3 read and cleared faults from at least some ecus but it isn't licensed to the L405 so can't even try to change CF settings. |
thats interesting re the 20/21 Craig....so there must be a setting somewhere in the CCF... ... - .- -.
Yes I’ve just double checked Stan and this one’s rear lights definitely come on with DRL. I’m sure it’s a CCF adjustment on 18+ 405’s sir… 🫶 |
